Ignition coil ohms .02-.04 ?
pointblank1000
So I just wanted to do a quick ohms check on a coil to see how HEALTHY it is. Specs say it should be between .02-.04. How does a person SEE this small reading on the scale?
Multimeter is set to Rx1 and zeroed.
Meter used is a micronta 22-214.
I have another meter but it's lowest sitting is 200ohms.
Chris1956
Micro ohms is a scale on some meters made for electronics work. usually you can see the difference between a dead short and not a dead short. if ign coil has not a dead short, the primary winding is likely good.
