bankerjohn
Thread starter- Joined
- Mar 21, 2008
- 444
My 9.9 Evinrude 4-stroke (E10FREDR, upgraded to electric start) has a problem running at any engine speed other than idle.
I have ruled out fuel tank pickup screen, primer bulb, fuel pump filter screen, and plugs (I installed new ones, properly gapped).
Before I dug deeper into the FUEL side, I thought I'd better check the SPARK. And since I've only got one of those in-line testers with a neon bulb (which you can't see in the sunlight, even if you have a good spark) ... I hooked up my trusty old Craftsman timing light.
If I crank the motor, and I connect the "probe" to the top plug wire, I get a rapid constant flash ... but when I connect to the bottom plug wire, I get very sporadic flashes, with the strobe being OFF much more than ON!
So ... my assumption is that the bottom plug is not getting the proper spark. Is my assumption correct ... or is this not a proper test?
I've attempted to test the coil, but the manual says that the resistance between ground and the primary terminal should be .28 +/- .05 ohms ... and my digital meter just isn't that accurate to properly measure. The other tests to and between the plug wire terminals are OK.
I checked the resistance between both ends of the bottom plug wire, and wiggled the wire around, always getting 0 ohms resistance.
I'm stumped ... should I just order a new coil, and new plug wires, and see if that cures my problem. Or is my timing light test not valid? Or is there something else I need to check out ... like the (shudder) ignition module?
