Re: ignition coil sparking on 95 evinrude spcl.88
Hi Jim!Thanks for your reply! In answer to your question,Yes, The spark was jumping like crazy ;especially at higher RPM,s.There was enough oil that the immediate area was wet.I installed new spark plugs(gap.030).The old plugs on the left bank were black,the plugs on the right bank were clean with presence of fuel.The motor seems to be running smooth under load.Still running about half speed at full throttle.Checked linkage on carburators,both are operating same.Butterflies are opening wide open at full throttle,closing all the way at idle.By the way,this motor was purchased about 2 weeks ago.Would run faster when first ran,but,still wasn't up to par.I am going to purchase a repair manual and a tachometer today.Also will check spark onall cylinders as you suggested.Thanks!
