BuzzStPoint
Thread starter- Joined
- May 27, 2009
- 1,003
I've heard you can test coils via MultiMeter.
Chrysler 55hp
Magneto engine.
Model: 555HA
Serial: x4949
Year 1970
I dont know how to test it, but from Plug wire to both red wires coming from coils gives a reading.
Coil 1: 6.05 ohm
Coil 2: 5.87 ohm
These readings correct?
The engine starts, but we found the upper plug not firing. Lower plug would fire but cut out for a bit. With some poking around I found the upper plug to have a loose connection at the plug boot. That has been repaired.
Plus is there a way to test the condensers?
Chrysler 55hp
Magneto engine.
Model: 555HA
Serial: x4949
Year 1970
Coil 1: 6.05 ohm
Coil 2: 5.87 ohm
