Ignition Coils
bertthedefender
I'm getting a poor spark on the number one cylinder of my 1991 70hp Force. Looking at the High Tension lead, the metal connector inside is corroded.
Is it possible to change just the lead (or replace the cap/connector) or do I have to fork out for a new coil? It appears as though the lead is permanently attached to the coil.
(Its Thunderbolt ignition btw)
bgbass.1
Re: Ignition Coils
before you buy a new coil switch with one of known good ciol and see if that fixes problem. and no you cant change the wire
roadrunnr
Re: Ignition Coils
You can replace just the boot and connector. The connector has, for lack of a better term, a spike that just pokes through the lead.
bjhc100
Re: Ignition Coils
Where can I get new caps and connectors, mine are all corroded and loose too. Can I use automotive type replacements? HC
roadrunnr
Re: Ignition Coils
That should work, just make sure it comes with the connector as shown in Sierra 18-5750.
