scout-j-m
- Joined
- Jul 31, 2009
- 643
My dad bought a 1992 Procraft 185 F&S a couple years back that came with a 92 model 150HP Blackmax, SN# 0D145256. I posted some about it on here a while back but long story short it had catastrophic faiure on the port side cylinders I think. He since found and bought a 1989 model of the same motor, SN# 0C184366. Motor had 120 psi across all cylinders and overall a pretty clean motor for the age. It's on his boat now and has worked well for a while it's just barely been used since he put it on. Last time out it wouldn't go over 3k rpms and wouldn't even try to get on plane.
I haven't done too much to investigate it nor water tested it since other than check compression again (still good) and checked spark. Spark seemed weak to me using a real spark gap tester. I truly doubt it's an ignition issue but, in the event it is, are the ignition parts from the 92 model interchangeable? There are a few obvious differences including having 2 rectifiers vs 1, 4 yellow stator leads vs 2, and the switchboxes having different part numbers. Just wondering if anything ignition-wise is cross compatible in the event I find an ignition problem on the current good motor.
I thought the two motors were almost identical but looking them both over the other day im seeing a lot of differences I wasnt aware of. Aside from ignition components the carbs are a different design and fuel pump a little different and different location.
