94fwfreedom
Thread starter- Joined
- May 27, 2013
- 26
I got confused while setting base timing on my 1994 four winns, and accidentally connected the G terminal of the four prong ignition module connector to a 12 volt source. I have been reading about the special plug needed to retard the timing, and though for sure that I read this somewhere. Well, fried the ignition module, and had this confirmed at the local auto parts store, as they have a tester there.
My question: can this module be sourced from a car engine? I know one should not use the cap from the automotive counterparts, as these are not very corrosion resistant, but have found that a 1986 Buick Skylark has the same HEI cap and rotor as the 3.0l omc/ mercruiser. Is the module the same too?
