skipper123
Thread starter- Joined
- May 17, 2010
- 74
I lost fire on middle cyl at idle as well as top end. Found by pulling plug wires while motor running at idle one at a time until I pulled one that made no change in the way motor was running. Swapped plug with bottom cyl still no fire on middle cyl. Swapped coil with bottom cyl still no fire on middle cyl, swapped plug wire with bottom cyl still no fire on middle cyl, swapped wires from switch box to ign coils between two cyl just to make sure the wires were not broken and still no spark at middle cyl. I can pull top and bottom plug wires and see a good blue spark between pulg wire and plug but no spark at all on middle cyl. plug wire. Well all this redneck testing can be done with a little know how and a pair of pliers and I have traced it back from the cyl to the switch box. Now comes the fun part trying to figure out if its the switch box or stator or maybe even a retifier ? I have a DVM but dont quite understand the DVA testing of the switch box as well as the stator. Have found both online for about 100 bucks each. My guess would be the switch box but my question is if the stator is bad will it burn out my new switchbox if I replace it first. My S/N- is 0B175091 and I hope the year model is 1987 not positive about that. Could anyone tell me if the stator will burn out the switchbox or power pack as some call it ?
