Ignition fuse blowing
mburgholzer
I have been blowing ignition fuses under the dash in my 1990 wellcaft 232 eclipse. It will run for about 1/2 hour and then just die. Have to replace the fuse and get another 1/2 hour. No new equipment hooked to it. Engine running cool at 160
Don S
Re: Ignition fuse blowing
It really doesn't matter in this forum what boat you have, we need to know what engine and drive combination you have. Full model and serial numbers are welcomed.
mburgholzer
I have a 350/325 hp @ 5400rpm. New motor from jasper. I have a Alpha 1 drive. I can get serial numbers tomorrow if needed. Thanks for your help.
EddiePetty
....sounds to me as though something is heating up during your 1/2 hour underways. Check all your electrical connections from the load side of the fuse, through the key switch all the way back to the coil. I suspect you'll find a hot terminal (connection) due to corrosion. (resistence causes heat,
more current is called for, more heat and so on until the fuse capacity is exceeded.
