maineiac5586
Master Chief Petty Officer
Thread starter- Joined
- Feb 14, 2009
- 828
working on early 90s 25 hp 2 stroke 2 cylinder motor. The ignition plate is loose. I pulled the flywheel and found all 4 nuts loose or not in place. I'm used to screws holding this bottom plate on not this stud and nut arrangement. The threads are very short for the second nut to go on and some threads are damaged I'm assuming from the nuts being loose. I can take out the stud/nut combo leaving threads exposed in powerhead. Do I put the ignition plate on first and then hold down with stud and nut combo without using the second nut? Should I just use screws in place of the stud and nuts? Please help
