Ignition Problems 91 V6
dsinger
I have lost spark to one bank on a 1991 V6 Suzuki. Unplugged both water flows, Neutral Switch Assembly, oil flow and level, and still nothing get spark back. Unplugged harness plug and jumped starter still nothing. Tested reset button and it is good. Any ideas would help Thanks..
dsinger
Re: Ignition Problems 91 V6
Does anyone have the bench test of the stator on this motor. (DVA)
JUSTINTIME
yes, you want over 100V
soundsl like trigger which just needs .7 volts
dsinger
What color is the wire from the trigger that needs the .7 volts and thank you for the response.
JUSTINTIME
they are white with tracer colors i believe
you should have 3 of them
