Ignition solenoid question
dubge
Is an ignition solenoid a sealed marine one or can you use an automotive one?
Wanted to go out tomorrow but can not get the marine one until Tue but can get an automotive one today. I just want to know if I should make plans to go out tomorrow or wait.
Thanks
Haut Medoc
Re: Ignition solenoid question
The Ford ones are same as auto.....
I'd bet the GM are, too......;)​
Don S
You can go out tomorrow WITHOUT the solenoid!
Assuming you are talking about the slave start solenoid used on Mercruisers, just connect the two yellow/w red strip wires from the solenoid together and it should start just fine till you get the proper solenoid that will fit.
dubge
I think the post is broken off that connects the ign wire to the distributor. When I take off the dist end and crank it over near a ground it is shooting a spark from the cap to the ground and not the other end of the wire that I took off the dist.
I have a buddy coming over to help me pull it out and check it for sure.
I have torn cartilage in my knee and havent been able to get in and work on it like I would like to
Thanks for the help, I will post later on what my findings were
Thanks
Ray
Don S
Are you sure you aren't talking about a coil instead of a solenoid???????
dubge
No I just thought it clipped in like it does on a spark plug, not that farmiliar with these things. I changed it out and still get no spark so I would guess the next step would be the ignition???
Thanks
dubge
oh and my mistake I beleive it is the coil
Don S
Well, now that you finally stated what your problem is, and there is actually no such thing as an "Ignition Solenoid" I have something that may help.
Don S
Also, if you actually have an 85 engine, you would need manual #9, if it's an 84, you need manual #3.
If you have a SN of your engine I could check what it is.
The serial number is above the starter on a brass tag.
Here is a link to download the manuals for free.
http://www-alt.mercurymarine.com/mnetdata/sisdata/srvcovr.pdf
dubge
Thanks Don, I am a dope, it is the coil not solenoid. I will do some more testing but everything is pointing to the ignition moduel.
My engine # is 686 2344
dubge
Can a thunderbolt 4 be replaced with an MSD or a different ignition?
Don S
It's an 84, you need manual #3 for your engine. That download is 1.36 GB in size. Unless you have a dialup modem, it may take days to download, if it will at all.
Might check on ebay for one.
The TB4 is a much better ignition system than the MSD, plus it is designed to work with the shift interrupt system.
dubge
wow an 84, thanks for that info. As for the ignition, is there an alternative I can p/u until I can get a TB4 or should I just hold out for the TB4?
As you can tell I am trying to get out on the water tomorrow :) I will wait if I have to but I am going to try like crazy to make it happen if I can
Thanks for all the help
Don S
Huh????????????
Do you mean the coil???? If all you need is a coil, check with your local Merc dealers. They probably have one in stock. Might also check with NAPA, they usually have them in the Sierra brand of aftermarket marine parts.
dubge
No I replaced the coil and beleive the problem is a bad thunderbolt ignition moduel and wanted to know if there is an alternative replacement for that from an auto shop because all the merc shops around me are closed til monday :(
Thanks
Don S
The modules are a Merc only item.
dubge
well looks like I will wait until monday
Thanks
again
