ignition swap ??
Frank Acampora
Re: ignition swap ??
Newer is not always better and in some instances worse. So, don't swap just because you want a "better" ignition. In fact both ignitions are the same. While I am not up on nthe years, the 89 will have ignition connections made on a terminal board while the 87 MIGHT have quick-connect electricals. Personally, I prefer the quick-connect version.
If you are handy at splicing wires, you can convert either system to be compatible with the other's components.
87force125
actually my cdi's got shorted out and they had a whole system on ebay for 50 bucks coils stator pick up flywheel the whole deal had the red mecury stator know where i can get 2 black cdi's cheap
