Ignition switch does not shut engine off.
mr 88
Twin 1996- 454s EFI Marine Power engines with a ECM . Toggle switch instead of standard key , same function, Mom on ( on ) - On - Off . Swapped switches, same result , not the switch. Wondering what is being killed and will try and back trace it from there . Any suggestions besides that ? I shut it down at the main control panel in the cabin , which has separate off - on ( no start ) switches for each engine as well. I have upper - lower controls along with main control panel and wiring goes into looms never to be seen again .
tpenfield
Tell us a bit more about your boat. I assume that this is a re-power?
I would suspect the wiring at the helm switches is not right, but having a bit more background would help.
I've driven one of your type but never got into the wiring. There is a main switch in the cabin which when turned ON it supplies power to the toggle switches at the helm. If power comes from the key or the cabin it comes in on the Red/Purple to your switches
The ON/OFF at the helm should have Red/Purple and Purple wire
The START should have Red/Purple and Yellow/Red wire
mr 88
Not a repower , worked fine when I pulled it , took the batteries out for the winter , dropped it in and this issue popped up . No wiring was touched in the off season . Wiring is good at the switches as we swapped switches with no issues , except the port side won't shut down .
Without a wiring diagram we're going to be guessing. Going to see if I can find find a diagram. Can you post some pics of the master key and helm switches?
dingbat
Check to make sure you didn’t drop a ground when you changed batteries.
Been there, done that
rallyart
Sounds a bit like the alternator field wire is not cancelling when you shut the switch off. If the field wire still has power then the alternator can keep feeding the ignition circuit. Test this by unplugging the field wire plugs from the alternators and then see if the engine shuts off with the key. Not harm from this, you are just running on the battery alone.
mr 88
Will give this a try next weekend, boat is 45 minutes away . So if it does kill the motor which wire am I back tracing , as you stated wires , to find the problem?
mr 88
One battery cable wire to each terminal and battery charger wires are all that go on the terminal post .
mr 88
Unfortunately, everything cannot be done alone. If you have a mechanic near you, I suggest you call.
I had a class A tech on board , along with the wiring schematic that Luhrs supplied . He was scratching his head . Told him to sleep on it for a couple days , will see him tomorrow afternoon and see if he came up.with anything.
rallyart
Not sure of the specifics on your alternator. Usually it's red in the plug that is getting ignition power. It's a separate plug and not the output wire.
mr 88
Interesting that this was moved , electrical problem on inboards , has nothing to do with outboards and is a repair . Not - non repair outboard + section. That's why I posted it originally in the main forum.
It was moved because it deals with a motor issue on the electrical side but by mistake moved to OB instead of inboard and IO. I moved to IO
WIMUSKY
My bad. A bunch of threads weren't categorized properly. It does need to be moved from Boat Topics and ?s. Since Marine Power engines were mated with different outdrives, it needs to be moved to your particular drive... If it's truly a helm issue, it needs to moved to electrical...
WIMUSKY
It's actually is in Non Repair I/O. I may have left a message of OB. Knowing the outdrive would be advantageous...
mr 88
Straight inboards, whatever I just want to fix the issue and would like maximum views . Lot of people just main forum it , don't scroll down.
dubs283
I shut it down at the main control panel in the cabin , which has separate off - on.......I have upper - lower controls along with main control panel
I read this as two station (cockpit/bridge) with full controls at each with a main 12 volt breaker panel in the cabin that has ignition breakers for each engine
The only way to shut the port engine down is by turning off the breaker at the main 12 volt panel, correct?
If so, the issue lies between the main 12 volt panel beaker and both helm stations. Could be an issue with the toggle switch at one of the helms, or wiring in between them. Does the other station power up when one station is used?
Best way to test this is with a multi meter and long test leads. You need to verify voltage, ground and continuity between all the stations/main panel.
My WAG at this point is faulty ignition switch at one station, chafed/worn wire somewhere between them or the panel or faulty connection causing a short to power
WIMUSKY
I get you want maximum views. Everyone does and there lies the rub. That's why we have subforums.
It's rare for me to look at top level, maybe when I'm looking for something specific, I always use the "What's new" botton
Bt Doctur
In, most cases the diode in the alt has failed and the alt is back feeding the system
