ignition switch evinrude powerpilot box
Dali30
Engine is johnson 85esl73m. -I found out that both + and - clamp on battery where dirty and gave bad connection,the starter run good after cleaning them. There where som leaders inside control box that needed to be sorted out better for space sake,one white from the start position switch rubbed against ground inside box,then suddenly all dead. Did this kill the ignition swich?
bonz_d
Doubtful. Look for a fuse inside the engine cover.
F_R
Honorary Supreme Mariner
White is the start wire. It would keep the starter from running----is that what you mean? It could also blow the fuse. But it shouldn't harm the ignition switch. Well I suppose it is possible, if the fuse didn't do it's job and blow to protect the circuit.
Dali30
Its two white that goes to the start-position switch,one of those where touching ground. Ok then i have to lokate the fuse first.
F_R
On the motor, somewhere near the starter solenoid, a bulging black lump in the red wire. Twist it apart and find the glass fuse.
Dali30
Yes that fuse was broken,could only find a type that is a bit longer but same 20 ampere,wrapped it in isolation tape and the starter works like a charm. thanks..
