pinellas50
Thread starter- Joined
- Aug 10, 2009
- 207
1996 Mariner 115. I just got done rebuilding the fuel pump and carbs on the motor along with replacing fuel lines. I have everything back together now and I went to start the motor to see if everything was OK. But now I have no power at the ignition switch.
During my work I didn't touch one single electric wire and I had the batteries shut off at the battery switch. I did have to unbolt the rectifier and set it aside but I never unpluged it. Now, I have power back at the engine from the batteries and everything not involving the ignition switch works. The guages get their power from the wiring going to the ignition switch and they come on when the switch is turned. All the guages are dead. I tested the wires going to the switch and I can't find power an any of them.
I have checked every fuse I can find both on the boat and the 20 amp on the motor. All check out fine. Tilt/trim still works fine too.
So my question is, where does the ignition switch get it's power from. Is it coming through the remote wiring harness from the motor? Is there something I may have bumped while doing my work that could have caused this? I have a manual but it doesn't really get into the non engine side of the remote harness.
