204 Escape
Ensign
- Joined
- Nov 17, 2007
- 909
Installed a new battery hoping for the first time outing today. Hooked up the battery properly, and found that I have nothing working. No guages, no lights, no ignition. (WOn't turn over, not even a click).
At first I thought I had gotten a bad battery, had it load tested, and it was fine.
Looked for blown fuses. Nothing.
Finally jumped from slenoid to ignition switch, and got lights, and guages, but wouldn't crank. In all fairness, I was using some jumper cables that were test lead extensions.
ONLY thing I can think of is:
1) Bad ground? (Trim button works)
2) Bad ignition switch
Ideas??
Forgot to mention this is a 2006 LARSON 204 Escape f/s with a 5.0 Carburated engine. BOat only has 76 hours on it, and NEVER gave a problem befors.
What is a TKS fuse?
Ideas??
What is a TKS fuse?
