glostah
- Joined
- Jul 12, 2006
- 28
I have a '82 Johnson 200 ona 25' Tiara that was recently hit by lightning that fried just about everything - see this thread:
http://forums.iboats.com/bbBoard.cgi?a=viewthread;fid=28;gtid=1169619
I'm still trying to figure out some stuff with the rewire so maybe somebody could help me with some basic ingnition switch questions. In the process of replacing most of the electrical system, I decided to replace the ignition switch as well.
The old switch had was a three pos, push to choke with accessory node. It had nodes for battery, magneto, ignition solenoid, accesory circuit and choke.
I replaced it with a Sea-Dog 420385-1 ignition that has a pretty similar configuration, except it has two nodes for the magneto. The diagram below shows the configuration.
The old ignition had only one node for the magneto with two wires that ran to it. One was a black/yellow wire that ran towards the engine and the other was a solid black wire that went to the ground block under the console.
When I installed the new switch, I reattached both old wires to the magneto circuit node. I then ran another new ground wire for the magneto ground on the new switch.
So I have three questions.
- Can someone briefly explain what the magneto circuit on the ignition switch is all about?
- Should I disconnect the ground wire from the original setup and just go with the black/yellow wire to the magneto circuit node and the new ground wire on the magneto ground?
- Would it have been at all possible to start my engine with the way I wired the new switch?
