Ignition switch wiring help needed
67cobia
I put my motor on a different hull and need help hooking up the ignition switch. The ignition has 6 terminals. I have all the wires (except for the purple) connected where they belong. I believe the purple is for the tach. The motor is a Mercury 125hp. Thanks Tony;)
Silvertip
Honorary Supreme Mariner
Re: Ignition switch wiring help needed
The tach connection does not go to the ignition switch.
A = accessory (powers the gauges) and in some cases the fuse panel.
B = +12 volts via the red wire in the engine harness.
C = Choke (primer) solenoid
M = Magneto
M = Magneto ground
S = Starter solenoid.
67cobia
My ignition switch has 6 terminials.
M-white
I-orange and blue
M-black
S-yellow
C-green
B-red
And then I have a purple that I don't know where it belongs.
Thanks Tony
67cobia
I don't know the exact year yet. But it is a Mercury Force 125hp made from 1984-88. If you need the exact year, I can post it tomorrow night.
Thanks Tony:D
67cobia
Still haven't figured out where the Purple wire goes. Please help. Thanks Tony
seabob4
The purple wire on any Merc is "ignition power". When the keyswitch is in the "run" position, it's hot, usually feeds your gauges and any other acc.'s that run off the motor. Pu a meter on the the back side of the switch and turn the key to run. Then see what terminal has voltage. That's where it goes. Just make sure there is no voltage when the key is off...
67cobia
Thanks Seabob! I'll check it out tomorrow night. And thanks to the others that also replyed. I have found this forum to have alot of good info in here. I've been reading lots of the old posts and looking at wiring diagrams. With this info I've gotten some of my issues with my boat resolved. Thanks Tony:D
