Ignition Testing on 1986 9.9 Mariner
333kelly
I have a 1986 9.9 Mariner. I have lost ignition to one cylinder. It seems that when it is cold, it fires, when it gets warm out or I run it and it warms up, the cylinder stops firing. I have read here how to switch the ignition leads on the coil and wherever the good lead is, it will fire, so I am assuming that the coils are OK. Here is my problem. My repair manual says to test the various components with an Ohms tester, but mine doesnt have the scales they want, 1 , 100, 1000. Mine has 20, 200 etc. HELP
333kelly
Re: Ignition Testing on 1986 9.9 Mariner
Sorry, should have read 1988 9.9 Mariner
JUSTINTIME
coil ohms
from both coil wire out put leads u should have less than 1 ohm
from the coil ground to the end of the spark plug lead u should have at least 1k
to test votage u need a dva
e-mail me and i can give u a write up
