Ignition Timing 3.0 OMC
Mr Wubbs
Does anyone have the correct ignition timing spec and idle speed for a 1988 OMC 140/ 3.0 motor?
Thanks
tschmidty
Re: Ignition Timing 3.0 OMC
The manual linked in the adults only thread has it, so download the manual and check there.
But if you would rather listen to some guy on the internet who is quoting from his imperfect memory, it's 8 degrees btdc, 28-32 dwell and 700 rpm.
But really? Check the manual.
