Ignition Wire and components??
Boater1010
Hi
Does anyone know where to get inexpensive replacement ignition wire? I want to replace mine on my 56 evinrude 30hp. I can get the wire, but the boot ends and clips i can not seem to find. The local autoparts stores you have to by a whole kit which is expensive.
thanks for your help.
schematic
Re: Ignition Wire and components??
make sure the wire you get is metal core (not automotive carbon core) Sierra sells a kit .
The boots can be had from evinrude and are nicer than any jobber that I found.
Boater1010
Hi
thanks for the response. I did order sierra wire, however I can not seem to find any part#'s for the boot ends and metal spring and clips.
schematic
I'll get you the number. Give me 10 minutes
bonzoscott
O'rieley's & Napa has those parts.
1946Zephyr
I bet you can find all that stuff right here at iBoats too
schematic
I don't think Iboats sells BRP. They will have the Sierra wires though. The Sierra boots are ugly
Boater1010
Can I use standard plug wires for a tractor? the local farm supply store sells wire kits for a 4cyl tractor for $12. Also does it matter if I use 7mm or 8mm wire?
thanks
schematic
Nothing special about the wires of that era. Solid metal core. All I can tell you is, some silicone based wire insulations do not stand up to oil. They swell up like a weiner and then fail.
The bigger the wire size the better, but mounting and routing gets tougher.
Boater1010
thanks for all your help. Much appreciated. take care
