Ignition wire: stainless steel or copper core
ward cleaver
Everyone recommends 7mm ignition wires. But there is a debate on whether it is better to use copper core (twisted strand) or stainless steel (twisted strand). It may depend on the year of the outboard. Mine are 1970 or older. What is your experience with ignition wires that you have replaced?
Daviet
Re: Ignition wire: stainless steel or copper core
I don't think I have ever seen stainless steel plug wire, have never asked about it, I have always used copper core wires. Don't see why the copper core won't work, has been used a lot of years with great success.
ward cleaver
I went out trying to find copper core and all the shops here said all they use is stainless steel and have done so for many years.
wilde1j
Doesn't make any difference, Cu, Fe or SS will all work fine, just no carbon filament resistor core wire.
Chris1956
Honorary Supreme Mariner
Merc uses stranded Stainless Steel. In saltwater conditions, I would think it would work better than copper or iron....
ward cleaver
My guess is that the inlanders use copper because thats what the OE used. But those in saltwater regions used SS to fight corrosion. Apparently there is no actual performance difference. I suppose I'll use SS just because that's what all the shops around here use. If I were planning on going out on the sound, I would definitely use SS.
