Ignition wiring w/ push button start
ktrahan81
I have a 1972 50hp Evinrude. I am trying to install the push button to start. I ran a wire from the battery to the push button, then froim the push button to the sylinoid. But the sylinoid just trips but wont turn the starter. Can i just bypass the sylinoid and just put a switch from the battery to the starter. I am going to leave my key switch on cause it turns off my motor.
Re: Ignition wiring w/ push button start
Only if you want to install very heavy gauge wire for the entire length and pay big money for a heavy duty switch that can reliably handle a couple hundred amps.
hidef
Sounds like your solenoid might be bad. You have made sure you have a good ground on the starter and all connections are tight.
