BoostedTimmy
Thread starter- Joined
- May 14, 2018
- 25
I have a Force 85 which I did a powerhead swap on. During the swap it was found that one of the wires leading to the rectifier was torched. I got a new stator (used part) and it had the different (newer) wire colors. It was pretty easy to to match up the colors, but upon assembly one cylinder didn't have spark. I got a second stator assuming the first part was bad, and behold the same problem. I looked at EVERYTHING electrical on the ignition and am absolutely positive my boxes are fine, the plug wires are fine, the plugs are fine, the coils are fine, and the trigger is fine. I swapped everything and the problem did not follow any of those components. I started tinkering and found I could get spark on all cylinders if I switched the pairs of stator leads that go to the boxes. Sometime during all this I also decided the timing linkage was put back on wrong and flipped it around, but I can't remember exactly when that was.
After getting spark on all 3 cylinders I did get the engine to fire, but as the starter was spinning it would often fire on one cylinder and totally stop the flywheel (bad sound!). Interestingly if I tried enough I could get it to idle smoothly and reliably..however..when I gave the engine some revs on of the stator wires going to the boxes went up in smoke! What was really strange to me is it continued to run fine and spark all 3 cylinders. I could get it started without that wire but it was still very difficult to get it going.
When testing it at the dock it was revving fine but that timing linkage got stuck against the block when I was revving it up. I thought I had it as the manual showed but decided I'd flip it around because there was no other way to get it to work. Since I was taking off the flywheel I decided I'd put the first stator I had got on and see if I could get it working since the previous one had that burnt wire. So I flipped that linkange and swapped the stator. When I went to put the flywheel on I noticed the key was partially cracked
I know for a fact it wasn't like that before. Everything back together and the original no spark on one cylinder problem is back, the flywheel stopping when a cylinder fires, and no start.
What could be going on here? It's possible the timing rod wasn't put back 100% as it was and I plan to check that, but that doesn't explain the stator not giving spark. Is the stator with the different colored wires incompatible with my motor? It looks identical except the wire colors. It's firing like I got the plug wires mixed up, except I know I don't! Missing flywheel magnet? What do you guys think?
