Ilmor/Yanmar Drive Trim Pump Relay issue
fatlenny
I suspect when you swapped out the 2 originally, you had them mixed up what socket was up and what socket was down, then making you assume incorrectly what one was good and what one was bad.
manders500
I tested them all on the bench and they all worked fine. I do need to test the drive for a longer period, but at this time it is working. I also marked the original good one.
If its not the relay it has to be a bad connection somewhere.
