I'm an Idiot, pivot pin removed
heloman29
I mistakingly pulled the pivot pin out of the lower unit on my 85 evinrude 25hp, anyone know how to get it back in? Thanks.
steelespike
Re: I'm an Idiot, pivot pin removed
Not likely but you can try a flashlight and an icepick to see if you can line things up.if you haven't disturbed anything it is possible.Otherwise you need to open it up and put things back together.
F_R
Honorary Supreme Mariner
I told the last guy that did that here that he was the millionth person to do that. You are number 1,000,001
heloman29
well I got the hole lined up but but it wont go into gear, any more ideas? how much of a job is this to fix if I have to dissasamble the lower unit, it is off the engine now. should I just look for a lower unit on ebay?Thanks guys
samo_ott
If you got it back in ok it should work. You do not need a new LU it only needs work.
heloman29
when I put the pin in I cant move the shift rod, and its just in nuetral.
Scaaty
OK...get a manual, pull it down, and fix it. Shift fork fell off the clutch dog/slider. Not hard, cheap, and now you will have a FRESH LU, not a basketcase possibility off ebay (manual would have prevented this in the first place...thats why we preach a Manual...)
