Gibbles
- Joined
- Nov 14, 2009
- 2,045
Another thing was the speedometer.
The seller told me that everything worked except that when I was looking at the boat.
I had a theory that the hose might have been pinched when he had the outdrive off for the bellows.
So in my spare time I watched a few youtube videos related to the outdrive and engine removal and reinstallation.
Then I ran across a video talking about the speedometer not working.
That video noted that there is a little hole on the front of the lower unit for the speedometer and explained that it's common for that to get plugged.
the fix is to run a little drill bit in there to clear it out.
In the video it showed water being trapped up in there, that made me a little concerned since I thought about cracking of the lower if water was trapped in there.
I ran outside with a drill bit and ran it into the hole by hand.
and 100% that little hole was clogged, and no water came out.
I'm feeling pretty certain that the speedometer has a very good chance of actually working this summer.
