Im thinking about buying this 1967 Starcraft, priced right?
jbcurt00
Re: I bought the 1969 Starcraft Holiday 18' from original family owner
JB Weld seems to be well liked for many scratches & holes
NOT Bondo
Tractors & boats go good together.
Sippen
Re: Im thinking about buying this 1967 Starcraft, priced right?
Drill out the rivets holding the end caps on at both ends of the gunwales. Check how much coverage they give you to confirm you can cut 1.625" (1 5/8ths) +/- off the end of the gunwale's tin. You might be able to bend it up out of the way, but it will probably crease the metal & that crease will likely remain when you try to bend it back.
I'm with you all the way, but trying to figure out the exact location you are removing the 1.625 off of. Any chance you could send me a pic of that?
I will send pics of her rear end tomorrow if that helps.. (me)
Uber thanks.
BonairII
He might be talking about this
I drilled out my transom brackets and used a dremel with a cutoff wheel. I replaced the transom wood and just pounded the metal back down. The cap covered and no crease(where i bent it back) showed.
jbcurt00
Yep, Bonair's got it
But here's the before:
BonairII
Just take a pencil and trace the shape of the cap before you drill it out/off...then you'll know how far you can cut/bend.
Sippen
Very nice, makes more sense now. thank you (picture is worth 999 words, the last one is left for my wife)
Sippen
NOT to be taken the wrong way, I love her and would gladly give her the last word.. : )
jbcurt00
We often use both: The Admiral & SWMBO (she who must be obeyed:rolleyes:)
I have previously referred to mine as The Warden in deference to her keeping tabs on me & my projects:facepalm: I'm sure if she was aware, she'd definitely prefer Admiral:)
jasoutside
Sippen! 800 bux you say? Sweet deal!
(So long as the Merc checks, which I suspect it will.)
Welcome man!:D
Sippen
ha, the Warden
And I'm learning so many helpful things here: swmbo
jbcurt00
And I'm learning so many helpful things here: swmbo:)
It may be best to keep some things from the ward --- Eerrp --- Admiral...
TruckDrivingFool
Nice job on the negotiating! I'd of probably forked over the extra $50 as once the "new boat" smell gets in my nose I tend to lose my will power.
I'll be looking forward to seeing how your new project turns out.
Sippen
Welcome man!:D
Thanks Jason, I put water muffs on the OB and water would not come out the top pee-hole (Mercury 70 1989). In fact the alarm went off on the throtle controller (over heating?). I shut it off but hope I didn't fry it. Crap.. what do you think this '69 boat is worth with no motor..? Prob $500 here in MI.
I have another thread on the engine.
ty
64osby
Sippin, nice deal.
If the alarm went off and you shut it down, no harm should be done. Time to put a new impeller or water pump in the LU. Pretty simple and not too pricey. You will want to drop it to see how the housing and plate look before ordering just the impeller.
Good luck
Sippen
Sippin, nice deal.
Good luck
Thanks, I really like this boat (been making extra trips outside just to take a look at it:)
I have been trying to drop the LU since yesterday. Read and searched online at how simple it is.. but it will not drop. I am not opposed to buying an OEM manual and read the one iboat sells is somewhat ok.. I removed the 4 main bottom bolts and the one above the prop and it will not budge. tapped it with a rubber mallet.. read there is a cotter pin on the shifter shaft near the top and I do not see it there.. If your familiar with this 3 banger, feel free to throw me a line.
model: 10704129D MERCURY 1989 70
thanks,
Captmills
great deal on the boat and you'll be glad you did the transom. Yeah you'll have to keep an eye on the Admiral for signs of boat fatigue, I almost got "the look" when I told her I ordered all new steering for the nassua but I added "at least it didn't happen out in the water" bob and weave LOL good luck and welcome
Bwana Don
I've used "The Fun Governor". ....only under my breath though. lol
We've got a really good Merc forum here. Sounds like you need an impeller. Get the manual first, it'll save you some heartache. Impellers are easy, peasy, lemon squeazy. That is after you do one, first one it's whaaat??? I'll check youtube, maybe some kind soul has posted a how to.
Sippen
Drove it to the shop, he said I just needed to use putty knife and wedges to separate the LU. Worked out great, new impeller installed. P-strem is good. Ty!
Bwana Don
Good deal.
Decker83
Good to see you solved the water pump problem. Looking forward to seeing more pics.
