impellar housing question
rock10
cobra outdrive,is the metal housing supposed to be round or sorta egg shaped mine was egg shaped when taken out to be replaced thanks
rock10
Re: impellar housing question
and also how do you get it out
HT32BSX115
Howdy,
You need to find yourself a service manual
It should just pull off. Here's what the new kit look like.....
rock10
thanks its off im talking about getting the metal impellar housing out of the cover appears to me from your picture that its oval shaped thanks
HT32BSX115
Yes. It is.......If it wasn't, it wouldn't pump water! Other pumps offset the impeller in a round housing to get the same effect. THis one is sort of like a "dual" chamber pump!
rock10
thanks now how do i get the old metal housing out to replace
cr2k
It should come out with gentle prying, but don't damage the plastic housing.
also it should sit level if it is tilted to one side your housing may be bad also.
