tommays
- Joined
- Jul 4, 2004
- 6,768
read everything here and it seams easy with the pictures i have seen linked to the posts on this <br />but one question . when i drain the gear oil i seam to be missing how the oil drains from the upper case to the lower case i only see the water tube there must be some type of oil passage because when i change gear oil it i pump it in to the lower case up through the upper case and into the plastic tank in the engine area.<br />thank you<br />tommays
