impeller confusion
Rob7Dawg
i recently purchased a raw water pump impeller for a aq271a, and the new impeller is shorter(31.5 mm tall) and mine is the same but taller(50.1mm) the part number that i came up with (876120) and on ebay i see they have both sizes. i have the shorter one here and i want to get the boat out this weekend but i dont want to put it back together if it will not fit correctly. i want to do it right the first time and not be on the water and fry the motor. i got a new bearing put in and a new seal. will this shorter impeller work or should i get a taller one and is there anything that i should do or look for when putting the raw water pump back together?
i thank everyone for all there help:)
Don S
Re: impeller confusion
You probably have a newer style pump than what was originally on your engine.
Rob7Dawg
i dont think it was anything special because it was red like the rest of the motor, will it hurt putting the shorter impeller in or should i order the bigger impeller like what was in it?
Don S
You can use the shorter pump, but it won't pump any water. You MUST have the proper impeller if you want to cool your engine.
Rob7Dawg
i thank you Don. i ordered the taller impeller.
