Impeller help, 1960 Johnson RDS-22
b717doc
Okay, got new ignition parts installed and gapped, and have a nice healthy blue spark at both plugs, found one arm of year old impeller broken off. Ordered and received new impeller, but not exactly sure which direction the little arms should be "bent" when I install it....If looking down at the installed impeller, should they be bent to the left, (pointing to left), or to the right? HURRY and thanks in advance...BTW, the book I have does'nt say....
steelespike
Re: Impeller help, 1960 Johnson RDS-22
With the gearcase upright;
Looking down at trhe impeller rotate it clockwise as you put it in place.
tashasdaddy
99% they will right themselves any way, once the motor is started.
b717doc
Will do, thanks guys....by the time I posted this last night, I did'nt have the energy to do anything else, will do tonight and hopefully put her in Allatoona Sunday....
