FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Hey guys I have a 2003 13 boston whaler. I made a video out of bordom one day and it would stay on. I've had problem after problem with my mercury but it also sat for 3 years. Is my impeller shot or what?http://www.youtube.com/watch?v=PfaaOBQVTTk
I could not watch the entire video ....it was painful
You need to replace that impellar or you will be doing an entire engine job. I have NO IDEA where you read that an impellar will loosen up but that is wrong.
It either works or it does not.
To change an impellar with the boat on dry ground, the proper tools and parts.... a novice can do it in less than 2 hours.
dude, that impeller change is easy, better fix that first, but note: if your motor has thermostat(s) no water will come out the pee hole until AFTER the water in the block goes past 143 degrees, even then it will cycle on and off at the pee hole. It also sounds and looks like you have either a fuel bulb that leaks back or a fuel pump that is not working properly. Could be the check valves on the fuel pump or a pinhole (or bigger) in the diaphram. Or maybe the idle mixture screw are adjusted improperly or idle RPM set way too low.
My RPM is good, today we ripped the engine apart, put in a new impeller (old one was fine but just for the heck of it) and found the pee hole had a small clog *facepalm*. The only thing that still remains though is the engine still makes a weird clacking noise but we determined something is wrong withen the 3rd piston or carb. We took that carb out but everthing was fine? Any ideas?
