Ok I was on the lake and the overheat alarm went off. Shut it down quickly and got towed to the dock. Figured the impeller was dead. Took it home and submersed the lower unit in a tank and tried to run it. It started but water was not coming out the outlets. Changed the impeller, gaskets, and wear plate. Housing looked fine. Opened up the thermostat cover and found no thermostat. The drive shaft for the impeller turned freely by hand when putting on the impeller. Have no idea as to why it won't pull water. Also with the lower end in the tank, I can't feel and suction at all by the water inlets. Any help would be great.
