scooper77515
- Joined
- Sep 3, 2010
- 753
Beginning of the summer season, I replaced all rubber hoses, impeller, and leaky o-ring. Used it 3 times this summer, and today, after 2 months sitting, the o-ring is leaking again.
Should I look for a slightly thicker 0-ring? Or should I look at some other cause of the problem?
Just a slight drip that flings along my fan belt, and drips out the bottom weep hole when the engine is off.
Pic and boat model and description below.
Also, since you are looking at the picture, should the impeller be installed with the brass insert toward the engine?
