oregonducker
Thread starter- Joined
- Feb 10, 2004
- 189
95 Johnson 48 Special.
Do currently available impellers for this motor require an o-ring between itself and the impeller plate like OEM or is that o-ring no longer relevant?
I'm replacing the water pump and ordered a kit. The OEM impeller has a recess on the bottom for an o-ring that sits on top of the impeller plate. The impeller in the new kit is not recessed for an o-ring but an o-ring was included in the kit.
I ran to the nearest boat shop and the impeller they have in stock also does not have a recess for the o-ring. I showed them the one I just took out and they did a good bit of research and couldn't say for sure if I had the right impeller. They think it no longer needs the oring.
Everything is identical between the new and old except for the o-ring recess on the bottom.
