Impeller on an SX-M drive?
dutch993
Hi I wonder if anyone could tell me where the impeller is on a Volvo Penta SX-M?
The 3.0 engine has it's own fresh water cooling.
Is it possible the impeller is mounted on the engine?
Thanks
dypcdiver
Re: Impeller on an SX-M drive?
Yes, just follow the hose from the transom, the pump is on the end of it, supplying raw water to the heat exchanger.
jerryjerry05
ALL Volvos have the pump in the engine compartment.
It's probably a belt driven pump.
insttech1
http://forums.iboats.com/volvo-pent...enta-raw-water-pump-625155-2.html#post4366511
Go to page one to look for diagrams, and page two of post to see actual pictures of unit and disassembled unit.
This post talks about the bracket-mounted, belt-driven water pump and shows the impeller on a '99 3.0 4 cylinder.
There is no impeller in the drive unit.
There are other versions with the main water pump/impeller mounter on the front of the engine, but most are the bracket mounted type.
raven1978
it is on the front of the crank pulley. there are two hoses attached to it. Remove the 4x 5/16 bolts and remove impeller. If doing this IN the water, disconnect intake hose and secure it up high otherwise you will take on water.
dutch993
Thanks guys for the responses.
I am starting to understand the system.
One other question I have - I see the line going into the heat exchanger from the transom, and a line going out as shown on the picture - this line goes into the manifold but then where does it go? I don't see a line going back to the transom?
skydiveD30571
The exhaust water travels thru the exhaust manifold and out the transom via the exhaust system.
jerryjerry05
Your lucky, not many 3.0 have a heat exchanger.
That extends the life of that engine a lot.
