Impeller pieces ???
dara64
Hello can someone tell me where Impeller pieces usually migrate to? My impeller in my lower leg was thrashed and now I?m wondering where did it all go?
Thanks
(1983 merc 470) yes yes I know !
Bt Doctur
Re: Impeller pieces ???
I had some stents put in to help the circulation in my lower leg but never an impeller.
What kind of leg do you have?????
Bt Doctur
assuming it`s the 470 mentioned at the bottom,
inlet hose, water pocket cover, inlet tube,power steering cooler, therm housing, manifold/riser water exits
havasuboatman
Ensign
It's been my experience that you will usually find them in the p/s oil cooler. Blow air backwards thru it with the impeller outlet hose disconnected. Then do some reassembly to see if you have all the pieces.
