Impeller problems.
raytom
Ok Guys, Last year I put the boat away with a impeller problem. I think I have a blockage. I burned a impeller last so I replaced it and took the boat out and burned another. The thing is that when I took the impeller out it had fins that were facing the wrong way. I know I put it in with them all in the right direction. I did run it on muffs at home and it worked fine. I checked it out after I ran it to see if there were any fins pointing in the wrong direction. There were none. Then I took the boat out and ran it at a good speed for about 20 mins and started to over heat. Whan I took it apart some fins on the impellar were in the wrong direction. Would a blockage couse pressure to build and move the fins or is it some thing eles. What common places may block up in a 88 4.3 omc cobra.
Any help is appreciated, Ray
Haut Medoc
Re: Impeller problems.
I'm am not an OMC guy, but are you sure you are putting them in the right direction?
On a Merc. Alpha Gen one they will right themselves as soon as the engine is started......
On an OMC, that might not be the case, they might want to stay put & don't as they start to fail......
You need to be sure of the rotation......
I'm sure someone will be along that knows way more than me on OMC stufff......:)
raytom
What way should the fins be directed? I did replace just as it came out. I have cleaned out the power steering cooler. Any other ideas?
Haut Medoc
I'm sorry, I am not an OMC guy, try adding "OMC" to your thread header to get the OMC guys answers......:)
Boatin Bob
Holding the housing in your left hand you should be turning the impeller clockwise as you put it into the housing, when it's in the blades will have a curl to the left or counter clockwise.
raytom
ok thats the way it was in. When Ipulled it out all but like three of them were curled the other direction. Any ideas?
