Impeller question
zackduncan40
Do I have this impeller in the right way or is this upside down? I wasn't sure so I figured I'd just ask
Xcusme
Psssst.....(you have installed it backwards.....reverse, to install it the right way....)
hardwater fisherman
Even if the vanes are the wrong way as soon as you start the motor they will right themselves. If you place the impeller on the wear plate with the key in place and turn the driveshaft clockwise while pushing down on the pump housing, it should fall into place.
