eightpointup
Thread starter- Joined
- Apr 23, 2008
- 32
Ok I just bought a Mercury 50hp I think its an 1982 by the serial 6148789. Turned the key and it turn over and I tried to start it about 10 times then the starter quit working. I gave it a little shot of starting fluid and pull started it with muffs on and it seemed to run fine but I shut it down because It wasn't peeing.
After testing for power through the solenoid and to the starter I still had 12.9v at the starter with the key turned. I ordered a starter.
Now for the water. My muffs did not seal well but I figure I should see some water flow. So I may take it to the lake and start it and see if the water will flow. BUT if I have to replace the impeller can someone point me to a page or video on how to do it on this engine?
Thank you,
Ron
Thank you,
Ron
