big jim 101
Thread starter- Joined
- Jun 26, 2009
- 3
hi i have a 1993 johnson 15hp and im changing the impeller i have the six bolts that hold on the lower unit off and i need help in direction to remove the lower unit. AM i suppose to unscrew the shifter rod linkage in order to remove the lower unit? Also i have heard that to take the lower unit off the engine must be shifted into reverse is this true? Any help would be greatly appreciated.
