Impeller replacement on Alpha One Gen 2 outdrive
dlogvine
I hope this post is in the right forum topic. I replaced the impeller on my Alpha One Gen 2 outdrive last year. Since then I ran about 15 hours on the boat in fresh water only. Should I replace it this year for annual maintenance or the gear lube change would do? Thank you.
harringtondav
I wouldn't after only 15 hrs. "Annual" can mean 50-100 hrs for some boats. My boat gets very low use each year, <10 hrs. I don't change my impeller unless I've split the drive for some other issue, like a seal kit.
Scott06
If engine was operating at proper temp no. Typically I see my idle temp creep up 5-10 degrees then change it.
dlogvine
Thank you, ill just change gear lube and regular engine oil change.
achris
More fish than mountain goat
Alpha One Gen II drives have a 3-year/300 hour service interval.
dlogvine
thank you buddy, that means all I need to do this year is change the engine oil :)
Also I was lucky, my wife got a job in Ace hardware so with her discount I managed to buy gear lube for a little over $4 for 2 quarts!
achris
... I managed to buy gear lube for a little over $4 for 2 quarts!
Don't think I'd be putting $2/litre oil in my drive! You save a few dollars ($10 at most) at the risk of THOU$AND$ of dollars worth of damage. That's not good economics my friend!
Things I don't go cheap on. Engine and drive oil, impellers, manifolds and elbows. Fuel. Oil and fuel filters. Basically, anything that risks more damage than the savings.
Chris...
dlogvine
Chris...
This lube oil is a standard penzoil gear lube at regular price of $9.99, I was lucky my wife got an employee discount. At first I though they forgot to ring me for the second quart. But if you think it is not a good gear lube, ill get another one quick silver or other marine brands. This one says marine gear lube for outdrives...
achris
Penzoil is a good brand, and if it has the marine additives (anti-emulsifiers, etc) then it should be ok. I am quite surprised you get it that cheap...
dlogvine
So was I, when I looked at the recipe and saw 4.99 for 2 quarts I first thought it was a mistake by the cashier, he forgot to ring for the second quart. But when I looked closer it was both for under $5. Guess my wife has a great workers discount there.
