Re: impeller replacement question
There are many issues that can cause overheating. When is yours overheating, always or just on plane? The raw water impeller should be somewhere on the front of the motor, it is a simple process, look in your manual. When you replace it, spend the extra $$ and buy an OEM. I find the VP impeller works better than aftermarket.
Have a great day,
Rob.
