Impeller service & gear position
Patrick_L
Some say neutral and some say forward 🤨 Which when pulling the drive down and back ?
Alpha one
Gen II
Ayuh,...... When reinstalling, Everything, has to be in forward,......
I use a bungee strap on the prop shaft to hold tension on the clutch, so's it Stays in forward,....
Patrick_L
Prop won’t be on the shaft at all during that time
Scott06
Bondo said when reinstalling you need to keep it from popping out of gear. If you dont keep counter clockwise pressure on the prop it will pop out of gear. You wont be able to mesh up shift mechanism or rotate the drive shaft to mesh with splines in coupler.
to remove drive put shifter fully forward. do not take the drive off in neutral
remember to remove speedo tube from drive before pulling it off
it would be worth your time to get a factory merc manual (#14) as details like this are outlined in it
dubs283
Irrelevant
All mc/r/mr/alpha style merc drives must be in FWD gear for removal/install save for the few counter rotated alpha drives still out there
Stinnett21
I use a homemade cart not wide enough to accommodate the prop so the prop has to come off for removal and stay off for re-installing. I hand turn the shaft so that the shifter stays in forward. Go slow and make sure it stays that way and lines up properly. Always in forward gear at the helm for removal and re-installation (assuming standard rotation). I believe counter rotation is the opposite but I don't have enough money to worry about that lol.
