Impeller shim availaility
bones774
Im replacing my outdrive after inspection and can't find the shim for the water impeller, is that part available or do i need to buy the whole pump? tried to find it on schematic and didn't, or what I should say is the piece is listed in exploded drawing but the p/n below the drawing do not look like the shim/key I need. Thaks
cr2k
Re: Impeller shim availaility
Since impellers don't use shims, you need to ask about the right part. Not sure what you are talking about.
