Re: impeller straight instead of curved
They are supposed to be straight when new. Over time they will develope a "set" with them being curved. The impellor housing is offset to the drive shaft, so as the impellor turns the fins straighten out on the water inlet side and then are forced to bend as they rotate around the other side. As the area between the vanes becomes smaller, as they bend, the water is forced throught the outlet into the water tube to the cooling system of your motor.
