impeller water pump kit
tav
I have a 2004 Johnson 40 hp 2 stroke outboard. looking to get a water pump kit, I did some research and found the some impellers have at least 5 tines , this particular one I found on line has only 3 tines .I do have a seloc manual and the pic shows 6 tines...probably a general description . 3 tines seems odd in my opinion .
Fleetwin
Re: impeller water pump kit
From what I can tell, the OEM, Sierra and Mallory kits all show a three bladed impeller.
alldodge
I come up with 6 blades
Water Pump Impeller for Johnson/Evinrude 396725, GLM 89710 - Sierra - iboats
Evinrude Johnson OMC 5031417 - Impeller @ MarineEngine.com
Exploded view (add www and boats and dot net)
parts/search/BRP/JOHNSON/2004/BJ40PL4SRS/WATER%20PUMP/parts.html
tav
is there a kit for that impeller? is there a difference in water push between 3 to a 6 blade? or is there no difference.
alldodge
Just looked up the kit and it shows 3 blades, so it is either a picture thing. I would say if it was designed for your motor 3 or 6 blades will work. Below is a link to the kits, find your hp and year (1999-up) and select the brand
Johnson Water Pump Repair Kits - iboats
cchildr84
For future reference if you see you self performing regular maintenance or repair work I would suggest an OEM manual. These Seloc & Climer manuals are to generic and don't provide model specific details and instructions. I got my OEM service manual from outboardbooksdotcom, which are provided by Ken Cook Manuals, which I am told now provides the OMC OEM manuals. Sometimes you can get lucky and find them on ebay as well.
rickdb1boat
Need model number to verify.Some use 3 blade, some 6..
oldboat1
Based on info from over on the Chrysler/Force section, fewer vanes is better (pushes a larger volume of water), so should probably go with the 3-vane impeller if there is a choice for your model. I've used both, depending what the make and model calls for, and don't see a practical difference. I was seeing 10(?) vane impellers when I was recently looking for an impeller for a 10 hp Chrysler I was working on (Ebay, I think, or one of the NAPA marine parts catalogs).
boobie
The 3 blade will push less water than the 6 blade but will work in that 40 HP for an engine temp issue at idle.
oldboat1
dunno, boobie. more might not be better. Is there some technical backing?
boobie
Only what I've experienced. Back in the mid 90's OMC tried the 3 blade in their 3 cylinder motors and found they would overheat. They went back to the 6 blade and it cured the problem. The OMC Cobra stern drives were running to COLD with the 6 blade so they went to a 3 blade to get them to run WARMER so they wouldn't make oil. That's from experience.
oldboat1
Thanks, boobie. interesting history. not a good idea on most bigger motors, so by implication not a good idea on the smaller ones if there is an option.
