Re: Imperial Deck Help
I shall attempt to explain the safety issue. The boat My friend and I are restoring, started out as looking GREAT, deck was ROCK solid, no signs of water anywhere. Only little problem was the fiberglass covering the motor mount block was cracking, So we decided to rip it out and rebuild JUST the motor mount. Upon cutting the glass for the motor mount we found a puddle of very dark and smelly water. Then looking up the keel with a flashlight we realized the entire hull has a very small puddle of water. When checking the underside of the deck we realized it was rotten and the reason it seemed so solid was because it had about 3/8" of glass over it.
Long story short, we removed the aft part of the deck and found the stringer to be "solid" when we removed the other two parts of the deck we realized that the water logged deck was holding the stringer down so it felt solid. The bilge box was rotted, the transom felt solid, did MANY core samples and found it rotting on the very bottom. It came out as well as the stringer.
The safety part comes in here...... With the stringer, deck and transom rotted the hull had a good amount of flex. When inspecting the bottom of the boat on a creeper I found a few larger cracks along with a looong 18" crack in the hull with brown stains around it. The Flex of the hull caused the cracks. Also caused the boat to take on water further adding to the rot problems.
Now imagine your a mile out, even if its just a lake and you have family or friends on your boat, water is choppy and your hairline crack takes a beating from a good wave. What might you think would/could happen in that situation, and would you knowingly put your family in harms way to save a few bucks.
Compare the boat to a car, you find your brake line has rusted through all the way in one spot, would you splice in a PIECE of line or replace the whole thing and check out the system before you put your family in it?
Just my two cents but when i have my family or friends in the boat i want to have piece of mind that my negligence wont be the cause of any misfortune.
